Total Members Voted: 124
Here's a modified plugin that allows you to use your own API keyAdding URLs works out of the box (the default API key is replaced with a new one)You can specify your own API Key, Client ID, Client Secret - without these credentials, any account-related features will not workChannel name in the Artist tagVideo description in the Comment tag" - Topic" is automatically removed from channel namesDownload (MEGA) (OneDrive)Setting up Google API credentials (API Key, Client ID, Client Secret)Create a project, enable YouTube API, obtain Client ID and Client Secret: guideImportant notes:Step 3: you need to check both '.../auth/youtube.readonly' (View your YouTube account) and '.../auth/youtube' (Manage your YouTube account)Step 4: select 'Desktop app' for Application TypeClick 'Create Credentials' once again and select 'API key'. It will be generated and added to the credentials pageOpen AIMP settings > profile folder > AIMPYouTube > Config.jsonFind "UserAppKey": "...", "UserClientID": "" and "UserClientSecret": "" lines and paste your API Key, Client ID и Client Secret in the quote marks respectivelyRestart AIMPOpen plugin settings and log into your YouTube account
Here's a modified plugin that allows you to use your own API keyAdding URLs works out of the box - the default API key is replaced with a new one.If it stops working, you need to use your own one (see instructions below)You can specify your own API Key, Client ID, Client Secret - without these credentials, any account-related features will not workChannel name in the Artist tagVideo description in the Comment tag" - Topic" is automatically removed from channel namesDownload (MEGA) (OneDrive)Setting up Google API credentials (API Key, Client ID, Client Secret)Create a project, enable YouTube API, obtain Client ID and Client Secret: guide(You can skip steps 3 and 4 if you only need the API key)Important notes:Step 3: you need to check both '.../auth/youtube.readonly' (View your YouTube account) and '.../auth/youtube' (Manage your YouTube account)Step 4: select 'Desktop app' for Application TypeClick 'Create Credentials' once again and select 'API key'. It will be generated and added to the credentials pageOpen AIMP settings > profile folder > AIMPYouTube > Config.jsonFind "UserAppKey": "...", "UserClientID": "" and "UserClientSecret": "" lines and paste your API Key, Client ID и Client Secret in the quote marks respectivelyRestart AIMPOpen plugin settings and log into your YouTube account
Только у меня не завелось это дело
Это не для людей решение, коль умеете - сделайте удобноВероятно, для каждого пользователя не нужен свой индивидуальный ключ
Всем доброго времени суток, господа. При действиях, которые указаны в файле "ReadMe" почему-то выскакивает вот такая ошибка. Может кто-нибудь подсказать в чём проблема? У меня стоит Visual Studio 2022
x64 папка лишняя
Установка плагина.1. Распакуйте архив2. Скопируйте папку плагина в папку AIMP\Plugins3. Откнойте Настройки >> Плагины, найдите плагин и включите его (можно просто перезапустить AIMP)4. Пользуйтесь
