Total Members Voted: 124
Хорошие новости по плагину, на версии AIMP 4.12.1873 перестала вылезать ошибка при закрытии плеера AIMP.exe: Memory Leak Detected. Версия плагина 1.0-RC3.
So how to remove them from exclusions?
New version:- Bug fixes- New languages (thanks prydespar and Sztewe!)https://www.dropbox.com/s/3jv0zjv040draq5/aimp_YouTube_v1.0-RC2.zip?dl=1https://drive.google.com/file/d/0B-f9jVoGmm7eWXVrZjFlZERwSWM/view?usp=sharinghttp://eddy.cx/files/aimp_YouTube_v1.0-RC2.zipWorks all good for me. Firewall or antivirus maybe?FixedIt works for me, did you try on another computer?I'm not sure if AIMP can handle streams starting in the middle, but I don't think so. One possible solution would be to load the whole video and then just seek to desired moment, but I don't know how practical that would be. I'll maybe investigate this later.This is not true, just check out the code.The reason it doesn't update actions text is I just don't recreate all menus and actions on language change, you have to restart AIMP. But language is not something you change every day so it's not a big issue I think
Open plugin options (Options / Plugins / YouTube) and click "Manage track exclusions". In the opened window delete tracks.updIt looks like this window is not there in v0.9.
File: https://www.youtube.com/watch?v=LXFZd_okfUkCode: -1 (FFFFFFFF)Message: Unknown Error-------------------------HTTP/1.1 403 ForbiddenLast-Modified: Wed, 02 May 2007 10:26:10 GMTContent-Type: text/plainContent-Length: 0Connection: closeX-Content-Type-Options: nosniffDate: Sat, 07 Jan 2017 13:14:25 GMTServer: gvs 1.0
