With Soundcloud plugin showing right click menu on aimp 4.10 takes about 3 seconds (aimp window hangs during that period).
Hi, if users will agreed, can you change behavior or add option then you click Like do not change playlist from Stream to Likes?Thanks
Adrian can you integrate with Music Library in similar way "VK" does?
Also you mentioned that 0.19 supports drag-n-drop, but when I try do that links from SoundlCloud as "Internet Radio" and apparently cannot be played. Is it plugin issue or AIMP limitation? "add URL from Soundcloud is extremely inconvenient" (sorry )Do you have workaround for this?
hey, I recently installed AIMP 4 and the soundcloud plugin, as well as the Bliss dark mod. When I try to hit connect, nothing happens. There's no response, and trying to add a URL ends with "could not resolve this url". I am currently logged into my soundcloud account, and have unblocked AIMP from my firewall. Please help.
So my steam was no longer updating so I updated the plugin today, however this didn't solve the problem, my stream still wasnt' updating. So I figured I would physically delete the playlist for my stream and recreate it however there is no option at all to add my stream as a playlist anymoreWhen I right click in the playlist section I get this: http://i.imgur.com/ELQm9FB.jpgWhen I hit the plus sign in the bottom corner I get this: http://i.imgur.com/uhrYflh.jpgI didn't delete my Soundcloud likes playlist and as you can see when I right click on files there I still have access to soundcloud options: http://i.imgur.com/FxQSfpS.jpgHowever no where is there an option to create a playlist based on my likes with the latest version of the plugin so some help would be appreciated.PS - I tried changing skins but that didn't solve the issue
New version:- Don't switch playlist to likes after like- Bug fixes- New languages (thanks prydespar, hs-sh.net and Sztewe!)http://eddy.cx/files/aimp_SoundCloud_v1.0-RC3.zipCouldn't reproduce. Could you check this on a fresh playlist?ChangedNot at the moment, maybe in the future I'll implement it. What is the problem with "Add Soundcloud url?" It needs to be added via that menu otherwise AIMP will think it's a regular URL to internet radio and won't use the plugin.does it still happen in v1.0-RC3? If yes, could you try to set other browser as default in your system?
Цитата: Zebbediah от Август 25, 2016, 13:33:21hey, I recently installed AIMP 4 and the soundcloud plugin, as well as the Bliss dark mod. When I try to hit connect, nothing happens. There's no response, and trying to add a URL ends with "could not resolve this url". I am currently logged into my soundcloud account, and have unblocked AIMP from my firewall. Please help.
"Could not resolve this url"https://soundcloud.com/alyandfila/fsoe-479
