TAIMP_SimpleVisual = class (TAIMPCustomPlugin){ ... }public // Методы для наследования // - Необязательные методы function vis_Init(Width, Height: Integer): HRESULT; virtual; procedure vis_Finalize; virtual; procedure vis_Click(X, Y: Integer; Button: Integer); virtual; procedure vis_Resize(NewWidth, NewHeight: Integer); virtual; procedure vis_AIMP_Message(Message: DWORD; Param1: Integer; Param2: Pointer; var Result: HRESULT); virtual; // - Обязательные методы, требуют реализации function vis_GetAutor: string; virtual; function vis_GetName: string; virtual; function vis_GetType: TAIMP_VISUAL_TYPE; virtual; // AIMP_VISUAL_FLAGS_RQD_DATA_SPECTRUM // Отрисовка procedure vis_Draw(DC_AIMP, DC_Buffer: HDC; Data: PAIMPVisualData; const Width,Height:integer); virtual;end;
AIMP_VISUAL_FLAGS_RQD_DATA_WAVE = 1;AIMP_VISUAL_FLAGS_RQD_DATA_SPECTRUM = 2;AIMP_VISUAL_FLAGS_NOT_SUSPEND = 4;
procedure vis_Draw( DC_AIMP, DC_Buffer: HDC; Data: PAIMPVisualData; const Width,Height:integer); virtual;
type TAIMPVisualDataSpectrum = array[0..AIMP_VISUAL_SPECTRUM_MAX - 1] of Single; TAIMPVisualDataWaveform = array[0..AIMP_VISUAL_WAVEFORM_MAX - 1] of Single; PAIMPVisualData = ^TAIMPVisualData; TAIMPVisualData = packed record Peaks: array[0..1] of Single; Spectrum: array[0..2] of TAIMPVisualDataSpectrum; Waveform: array[0..1] of TAIMPVisualDataWaveform; end;
TSimpleWave = class (TAIMP_SimpleVisual) public function vis_GetAutor: string; override; function vis_GetName: string; override; function vis_GetType: TAIMP_VISUAL_TYPE; override; // Отрисовка procedure vis_Draw(DC_AIMP, DC_Buffer: HDC; Data: PAIMPVisualData; const Width,Height:integer); override; // Init function vis_Init(Width, Height: Integer): HRESULT; override; // Обработка сообщений procedure vis_AIMP_Message(Message: DWORD; Param1: Integer; Param2: Pointer; var Result: HRESULT); override; // Клик по визуализации procedure vis_Click(X, Y: Integer; Button: Integer); override; public showTextTime: Integer;end;
function TSimpleWave.vis_GetAutor: string;begin Result:='SimpleWave Autor';end;function TSimpleWave.vis_GetName: string;begin Result:='SimpleWave Visual'; showTextTime:=0;end;
function TSimpleWave.vis_GetType: TAIMP_VISUAL_TYPE;begin Result:=AIMP_VISUAL_FLAGS_RQD_DATA_WAVE; // запрашиваем волновуюend;
procedure TSimpleWave.vis_Draw(DC_AIMP, DC_Buffer: HDC; Data: PAIMPVisualData; const Width, Height: integer);var ci,x,z,y, offset: integer; br: HBRUSH; s: AnsiString;begin // отрисовка // Все рисование идет на DC_Buffer, и в самом конце переносится на DC_AIMP через функцию BitBlt // Очистка экрана br:=windows.CreateSolidBrush($3C3C3C); windows.FillRect(DC_Buffer, Bounds(0,0, Width, Height), br); windows.DeleteObject(br); offset:=trunc( Height / 2 ); // << CSS совместимый цвет y:=0; for ci:=0 to High(Data^.Waveform) do begin for x:=0 to Width-1 do begin z:= Trunc((1 - Data^.Waveform[ci][x]) * offset / 2); if z < 0 then z := 0; if z > Height then z:= Height -1; if x = 0 then y := z; repeat // draw line from previous sample... if y < z then begin inc(y); end else if y > z then begin dec(y); end; if (ci = 0) then begin windows.SetPixel(DC_Buffer, x, y + round(offset / 2), $FFFAFA); end; if (ci = 1) then begin windows.SetPixel(DC_Buffer, x, y + round(offset / 2), $00FA9A); end; until y = z; end; // end for end; // end for if (showTextTime>0) then begin// показываем текст в случае если таймер showTextTime не истек dec(showTextTime); s:= 'AIMP new track'; Windows.SetBkColor(DC_Buffer, $3C3C3C); // фон Windows.SetTextColor(DC_Buffer, $00FA9A); // текст Windows.TextOutA(DC_Buffer, 2, Height-15, PAnsiChar(s), Length(s)); end; // Копируем буфер на DC_AIMP BitBlt( DC_AIMP, 0, 0, Width, Height, DC_Buffer, 0, 0, SRCCOPY );end;
function TSimpleWave.vis_Init(Width, Height: Integer): HRESULT;begin showTextTime:=0; Result:=inherited vis_Init(Width, Height);end;
procedure TSimpleWave.vis_AIMP_Message(Message: DWORD; Param1: Integer; Param2: Pointer; var Result: HRESULT);begin if Message = AIMP_MSG_EVENT_STREAM_START then begin showTextTime:=60; end;end;
procedure TSimpleWave.vis_Click(X, Y: Integer; Button: Integer);var s: string;begin s:= 'WIN_DLL_Path: ' + AIMP_SimpleVisual.GET_WIN_DLL_Path + #13#10 + 'APPDATA PATH: ' + self.visAPPDataPath ; Windows.MessageBoxW(0, PWideChar(s) , 'AIMP Click Event', 0);end; ;
