http://i.imgur.com/ZKWFZ1b.png
Hi, i just downloaded your skin and it looks realy smart. I just wanted to know if it's possible to include a CD cover to the CD coming out the album, and an artist cover for the background, as the album cover is repeated three times. It would level up even more your skin
Спасибо! +1, без пол литра не разобраться... а без инструкции тем болееИмхо эти настройки должны быть пофиксены по умолчаниюБыло бы неплохо добавить меню на кнопку Play\Pause, для остановки, остановки после текущегоputra05Please add the button: Play\Pause-> PopupMenu -> pmStopOptionPlease add the CoverArt PopupMenu -> pmDisplayimho be default
I just found out about Aimp yesterday and after I looked over all available Skins I finally stumbled upon this little fellow.After giving it a bit of a trial, I can say that the Combination of Aimp and Ora Mulih is quite the ticket.You´ve done a great job!Not only the main-interface scored but also the Equalizer. I have 1920x1200 Res. on my NB so the default EQs seem to be very often pretty tiny. For me, yours is just perfect in every way.Still I have a few suggestions:First a question: is it a big thing to make the four elements main/eq/visualization/albumart modular? would be a nice high res solution if one could assemble them freely together. First suggestion: Ora Mulih -modular version.The second one refers to the jpeg in the attachment. On the right side there is Codec(mp3),Bitrate(192kbps) andsamplingrate(44khz).I would use the space to full capacity and display there more information (eg: filesize,length) and in this process scale eg CodecInfo down (guess, needless to say). I would surely also change the font colour to have a little more contrast. Its a bit hard to read like that.My third and last suggestion ist also related to the location the attachment displays. I like the small size cause some of my pictures have bad qualitiy.. but I would nevertheless enlarge the AlbumCoverArt on the left between 5 to 10mm diagonal. I guess you wont have to resize the whole section for that and it would make a difference.I read you dont have a lot of time now, but anyway, you asked for it hopefully you find some day time to continue your good work. I forgot the UI Editor: nice one! AllinAll very well thought out.thanks a lot mateEdit: IF YOU EVER want to create a modular version of this fine Skin, I would let go of the additional sound effects or, idea: integration in UI Editor therfore optional . In All-In-One Version is, like you have realized, space no Problem, modular on the contrary... Greetings to Russia
right click on button: Play\Pause main menu it used for show now playing and Long press for Stop
hmm, select skin ?
