+1 Good job
but not what I expected to see after reading the title.
Do you mean "Electro" or that the skin is All-In-One?
Under the "Electro" I seen something with zippers
Hi. I established a cover as the main worker, but it would be desirable to add some functions, for example: to add the counter of time of playing of a track and also that when aiming at a strip of scrolling (SeekBar), progress not as a percentage, and in minutes and seconds was displayed.You could make these additions or send me on e-mail the project that I could make the necessary changes independently. Thanks.
Hi.1. "to add the counter of time of playing of a track". But it isn't already one (right next to the visualisation area)? Or do you mean something different? By the way, you can click that Track Position area to switch between Current Track Position and Remaining Track Position.2. "progress not as a percentage, and in minutes and seconds was displayed". OK. I'm working on the version 1.1 that will have some changes, including this one. Also I'll replace the Mute button (useless IMO) with a Tag button that shows the Quick Tag Editor for the selected file(s).
1. Yes, you understood correctly. Another counter to the left of logo. I need it for more accurate tracking Progresa track playback.
2. At the expense of a button, I think it is still worth saving, or move it to an icon instead of the icon of the album, as it is very small and confusing him with not a lot, but there mute button will look harmonious, just above the volume control. Either make mute, right-click on the volume control.
And yet, it would be nice if when playing a track, play button somehow stand out, such as glow when you hover over it with your mouse. When you want to quickly enable, disable, switch tracks, sometimes it is not clear whether or not the track is playing.
I'll keep the current dimensions. But I can send you a special version with 2 counters and a reduced size. What size do you want (width in pixels)?
Yes, thanks. Counters, mute and scrolling that is necessary. There is one more nuance which it would be desirable to change, т.к in my opinion it is beaten out from an overall picture and makes callous an eye, it is a strip of allocation of the lost track when the strip is on a track which is lost at present, at a track tags from below aren't displayed. I don't know, can do it such counter, but it seems to me is allocated from the general background. If to you it isn't difficult, you couldn't eliminate this moment.
I don't understand what you mean.
