AIMP for Android v4.30
Winamp AVS?
Topic: Winamp AVS? (Read 23310 times)
Winamp AVS?
April 10, 2015, 06:19:29 »
Terrapin
Hey, I read a few threads of people using Winamp Wrapper v0.2-0.3 to run Milkdrop music visualization. I was wondering if Winamp AVS was compatible in any way with AIMP. I tried moving vis_avs.dll to /Plugins, renaming it to vis_avs.svp, and editing the .ini file to add AVS... but I'm under the assumption that the context within AIMP3.ini is created when the AIMP.exe is launched.
I'll try to experiment with aimp_vis_winamp and see if I can come up with anything. I'm rather new to editing ini and js files, but maybe by some miracle I can get some sort of results
It would be really cool to see Winamp AVS working with AIMP.
Re: Winamp AVS?
October 04, 2021, 22:12:48 »
Desert dessert
Карма: +1/-0
[Win10 x64] [AIMP5]
I know this topic is very old but FTR I had no issues of using aimp_vis_winamp plugin with v2.8.1.4 of
vis_avs.dll
Winamp AVS?
