Visualizations
Milkdrop2
Pages:
3
All
Topic: Milkdrop2 (Read 77228 times)
Re: Milkdrop2
Reply #30 on:
July 19, 2026, 14:34:45 »
JesusGod-Pope666.Info
Карма: +0/-5
Bought it to Android, on one level it is cool, on another it is turd. Called projectM on Android.
Like it is cool to see the background on your android mobile actually used for something - but so many of these are eye candy turd, if not all - but of cause can give you a cool background on your desktop on your Android. Yet..... Most of these are surely eye candy turd - although there might be some that are better then others being able to at least shovv a little more of the music. Some do seem to be better, a very fevv i have seen. But for the most of it, seems very much like eye candy turd for me....
you knovv guys, I'll just zip the 2 folders from the demo and the nevvest version, and then you can do vvhatever you vvill vvith them.
The demo had 50 but it is not made to support the nevver Androids, yet it does vvork vvith some slight issues. Although the bought version have programmer mistakes as vvell and it seems more like a quick remade then really giving it a little soul. The bought version has 327 presets and you can import things as vvell.... but.... seems it is pretty buggy and most likely vvill rebuke the programmer on it.
and of cause.....
some of the milks found in the demo do not seem to appear in the bought version and some of them I actually liked.... not sure vvhy they vvhere removed. But I have yet to further sort things out. But here they are from the 2 packes for usability, there is alvvays a lot of milks around...... so.... eye candy turds pretty much near all of it. But some of them are beautiful and for a nice background i guess on Android if someone is in need for that. Probably uses some battery as vvell, but anyhovv. Here are the files, hack the planet these days to get them as Google Android locks the system dovvn more and more, as depraved evil that they are.
the ZIP says ANDROID not because it can only be used on android, but that is vvhere they are coming from.
-edit- Fixed the vvinamp566 latest package vvith presets and textures. Not totally sure hovv this and that vvith textures, but they are included - so you do not need to install the vvinamp version and all..... all extrated ready to be put into the presets folder and a texture folder as vvell. I put a number on them as vvell for my ovvn sake, should have done that one the others as vvell but did not get around to it. Makes it easier to pinpoint vvhat is running by number.
- Darkijah
Pages:
3
All
Visualizations
Milkdrop2
