Suggestions (archive)
Implemented in AIMP v4.60
[Реализовано] Can Bit Depth display be added?
Topic: [Реализовано] Can Bit Depth display be added? (Read 6141 times)
August 22, 2018, 05:50:23 »
sveakul
Карма: +79/-1
Is there a way to add Bit Depth to the Playlist/Format Settings and Running Line displays? Already shows in File Info/basic/Quality Info--- am I just missing the right format code (%BitDepth is a no-go)?
Re: Can Bit Depth display be added?
August 22, 2018, 09:27:14 »
Карма: +3188/-76
I planning to add this macro for playing track in next version of AIMP
August 22, 2018, 19:39:27 »
sveakul
Карма: +79/-1
Great, thanks Artem for the reply!
