Development
source code from a simple plugin?
Topic: source code from a simple plugin? (Read 12212 times)
January 14, 2013, 12:15:01 »
lcjury
hi, i'm looking for some source code of any plugin, just for learning ends...
i can't make work the sdk
if somebody could help, it would be awesome.
Re: source code from a simple plugin?
January 14, 2013, 12:20:25 »
Карма: +1406/-190
in the SDK there is an example
https://aimp.ru/forum/index.php?topic=30328.0
(folder aimp_api\Delphi\Demos)
and
https://aimp.ru/forum/index.php?topic=34041.0
and
https://aimp.ru/forum/index.php?topic=34235.0
January 14, 2013, 12:47:36 »
lcjury
thanks
!, but... i forget to say, that it would be awesome if it is C/C++ source code.
January 14, 2013, 13:06:51 »
Тестер 3-го уровня
Карма: +628/-37
0x546172696B
https://aimp.ru/forum/index.php?topic=36363.msg219687#msg219687
Development
