Can't post or get to/from Internet from within my plugin
Topic: Can't post or get to/from Internet from within my plugin (Read 9691 times)
January 06, 2013, 00:42:45 »
vhanla
Hello, first and foremost, thanks for this awesome audio player, I love Aimp3 and use it almost everyday.
I wrote a simple plugin that scrobbles to LastFM, it works perfectly as an external application, but it can't work as a plugin and throws the following error.
Access violation at address 0762F9D0 in module 'LastFMScrobbler.dll'. Read of address 000003E0
I don't know why, it doesn't work.
BTW: I'm using Delphi and Indy, I also tried with Synapse components for Internet communication.
I need to do a GET & POST to ws.audioscrobbler.com that is only HTTP (using latest LastFM API), SSL is not required.
Is there any way I can achieve that? I don't know if your plugin system limits some routines on purpose for some reason.
Anyway, I am using an external executable to make it work.
Last Edit: January 07, 2013, 14:01:31 by vhanla
