[DSP] PushTec
Topic: [DSP] PushTec (Read 13367 times)
[DSP] PushTec
August 19, 2012, 11:50:16 »
Карма: +473/-73
6-полосный СЧ и программный EQ.
Алгоритм за просто потрясающий пользовательским интерфейсом на основе принципиальной схемы одного из самых востребованных классических аналоговых эквалайзеров - хорошо, два, если быть точным. Имеет хороший ясный пользовательский интерфейс и легко начать настройку.
English
Description
6-band midrange & program EQ
The Leftover Lasagne PUSHTEC 5+1A is a 6-band midrange & program EQ. The algorithm behind the simply stunning user interface is based on a circuit schematic of one of the most sought-after vintage analog EQs - well, two to be exact. We combined a superb program EQ with a rare midrange EQ to end up with a very flexible all-around tool for your mixing and mastering sessions.
Staff Review:
The reference to pasta in this was a bit weird but this has a good clear UI and is easy to start tweaking. I think you need to know what you're doing though to get the best out of this (which does come with a large number of predefined settings so is enough as a basis). A large dll/installer but the effects worked well so not something to hold against it.
Скачать
Last Edit: November 13, 2023, 15:19:35 by Artem
Re: PushTec
August 21, 2012, 20:50:45 »
Карма: +1406/-190
странный плагин
большой (размер файла) и непонятно-бестолковый (интерфейс и управление ручками)
покрутил, покрутил и кинул =)
Re: PushTec
September 02, 2012, 01:34:18 »
sagitt67
Карма: +121/-20
4 Monitor Audio + Pioneer
Попробовал и остался на DFX (мне удобнеее).
[DSP] PushTec
