Imperator3
Kr1eger
[FULL] Splash Pro (All-In-One) [AIMP3]
Topic: [FULL] Splash Pro (All-In-One) [AIMP3] (Read 26466 times)
January 13, 2012, 22:49:07 »
memo-se
Карма: +135/-4
Splash Pro All-In-One Skins for AIMP3 Player
Versiyon ,Version : 1.1
Yazar ,Author : Memo-se
Original skin :
http://mirillis.com/en/
Download:
http://memo-se.deviantart.com/art/Splash-Pro-All-In-One-Skins-for-AIMP3-Player-279174144
Kolay Gelsin
Sanatini Göstermek Güzeldir
Last Edit: March 09, 2012, 02:44:45 by Tarik
Re: [FULL] Splash Pro (All-In-One) [AIMP3]
January 14, 2012, 08:57:08 »
LS
Карма: +31/-21
Not a nice upper-right corner, it would be rounded off. The top and bottom corners are different - so it should be?
In general, skin like "+"
Не красивый верхний правый угол, его бы закруглить. Верхние и нижние углы отличаются - так и должно быть?
В целом скин нравится "+"
January 14, 2012, 13:51:04 »
memo-se
Карма: +135/-4
Thank you for your interest
June 05, 2017, 16:19:37 »
Dreamer
Завсегдатай
Карма: +12/-0
I like this skin, I found it also for PotPlayer and I'd like to use the same skin in both players.
However, I need a standard, vertical skin, with options to show and hide the playlist, equalizer (and visualizations windows).
I tried to find a standard version of the skin on this forum, main AIMP site with skins, Devianart page, but I couldn't find it.
Is the standard version (not all in one) of this skin available? If not, could anyone create it? With the same buttons. Or at least move the main buttons (play/stop..) from bottom to top and the playlist tab bar from top to into the middle (above the playlist area, or just to bottom).
Thanks in advance.
Last Edit: September 01, 2017, 16:43:01 by Dreamer
Imperator3
Kr1eger
