AIMP for Android v4.30
How to install plugins into the v3.60
Topic: Установка плагинов на AIMP v3.60 и новее / How to install plugins into the v3.60 (Read 156277 times)
August 11, 2014, 09:44:51 »
Карма: +3191/-76
In 3.60 (4.00), each plugin has its own personal working folder, its name must match the name of the main DLL file.
Installation steps:
1. Unpack old plugin. For example, you got the aimp_ultraMix.dll file
2. Create the "aimp_ultraMix" sub folder in the "AIMP3\Plugins" folder
3. Copy the aimp_ultraMix.dll into the "aimp_ultraMix" folder
Note for visual plugins: you should change the .svp extension to the .dll
Last Edit: December 25, 2025, 12:13:44 by Artem
