Общее
General
Фагот
ASIOKS for 24bit/96kHz USB DAC
Topic: ASIOKS for 24bit/96kHz USB DAC (Read 7563 times)
December 30, 2011, 05:22:55 »
Dac2012
Guest
Direct output to WDM audio drivers passing through the Kernel Mixer
Install
regsvr32 Path...AsioKs.dll
Uninstall
regsvr32 /u Path...AsioKs.dll
This software is output only. If you want to use 32 bit mode,
ASIO: AsioKs
Select Output Device
Select Sample rate
Adjust Buffer Size
I am using 24bit/96kHz USB DAC.
Device: ASIO: AsioKs
Output: 96000Hz / 32 Bit / Stereo
Decoder: 48000Hz / 32 Bit (Float) / Stereo
Core Status: 64.84 MB / 32 Bit
Общее
General
Фагот
