you mean I have to downgrade to 32-bit version of aimp from the 64-bit
Yes, this plugin is for 32-bit app version
reddino, reinstall v2.0.3 from catalogue/first message.
it doesn't work
I don't have any pictures on my PC or on my hard drive. Interesting? how is this possible?
But I cannot find it anywhere. What's wrong?
I assume 64. Where can I find that information?
Should I exchange it with the 64 bit version (is there any advantage to use that one)? If yes, how? Just copy it over the 32 bit one?
You're fine keeping the 32-bit AIMP, it works just as well as the 64-bit one.
