AIMP3 "Now Playing Plugin"
Topic: AIMP3 "Now Playing Plugin" (Read 18153 times)
December 22, 2010, 16:15:24 »
Dex
AIMP3 Live Messenger 2011 плагин.
Last Edit: January 04, 2012, 23:58:54 by Soolo
Re: AIMP3 "Now Playing Plugin"
October 24, 2011, 00:11:35 »
Jaroslav
Чё он делает
October 24, 2011, 06:22:37 »
Карма: +476/-74
Description Customizeable MSN "What I'm listenig to" plugin
Another MSN plugin for Winamp. Tested with Winamp 5.24 and Windows Live Messenger.
The displayed text can be customized, it can contain the following fields: title, artist, album, genre, year, filename, and playback status.
You can also enter custom text which will remain as is. For example, if you are playing the song X performed by Y from the album Z in 1987, you can set the plugin to show this: "I'm listening to X from Y (Z, 1987)" with the setting text of "I'm listening to TITLE from ARTIST (ALBUM, YEAR)". It's that simple.
З.Ы. Выставляет статус в этой программе \ У меня работает не корректно для радио
Last Edit: October 24, 2011, 06:40:29 by Алекс
