"Now Playing" Screensaver
Topic: "Now Playing" Screensaver (Read 15861 times)
December 17, 2009, 00:55:31 »
Fad
http://www.winamp.com/plugin/now-playing-screen-saver/133688
This may have been mentioned before, but it`s a "Now Playing" Screensaver for winamp that works with Aimp...
Just thought I had better mention it in case someone was looking for the same
Re: "Now Playing" Screensaver
December 26, 2009, 18:33:57 »
motomast3r
Карма: +2/-0
good plug-in i use this now thanks
Fad
April 28, 2011, 21:39:02 »
Tron
Завсегдатай
Карма: +5/-107
Z228135698387 B396695415940
"Now Playing" Screensaver, прочти кириллицу!
May 08, 2011, 19:58:08 »
NotStyle
Карма: +2/-0
How can i use it with aimp3 without installing winamp? (win7 64bit) ;]
May 24, 2011, 21:35:42 »
+Fix
Завсегдатай
Карма: +33/-4
+Fix
i guess you should try this, its was for dfx, but might work
https://aimp.ru/forum/index.php?topic=148.msg134711#msg134711
but i think you dont understand Russian, i will translate it to english for you
1. Make in C:\Program Files empty folder named Winamp, in that folder make empty file named winamp.exe
2. Now make text file with notepad or something, and paste in that:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Winamp]
"DisplayName"="Winamp"
"UninstallString"="\"C:\\Program Files\\Winamp\\UninstWA.exe\""
3. Save it as install.reg (NB: not install.reg.txt) then run it and let it make changes to registry
4. Then install the program you want, and search its file in winamp/plugins folder copy it to Aimp3/plugins folder
5. Delete C:\Program Files\Winamp folder
6. Make new text file or modify install.reg you made before, but now you have to paste there:
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Winamp]
7. Run it, let it make change to registry and you are done.
Hope it helps
Last Edit: June 22, 2011, 14:14:54 by +Fix
