If you have multiple folders… There are not the Option Group by Subfoders
Second the search function arent working korrekt if many folders are collapsed
There Should be an option to collapse all Folders or group thinks
4. When I play somethink from the favourite and I do accidently do unfavourite the track, the next will be Played. I used this method to sort my Favourite List
5. More Hardware shortkey events
6. Sometimes when I accidently swipe the player display on the lockscreen away. It never apears again! Then I have to stop it completely and restart aimp
7. When I tab on bookmark. It Displays immedently the player with the new track (at bookmark time)
8. You haven optimize the app for less wakeup calls.
9. I cant sort bookmarks and favourites by mod date or so..
10. I dont want to have the possibility to change the current play time at the music library. (Sometimes I click accidently to the wrong time)
11. You should have a Jump back to previous time if you accidently click to wrong time stamp.
12. In non random play mode I cant switch back to the last played track (only in random mode this works correctly)
12. You havent bubbles enabled
