Fade in/out
Topic: Fade in/out (Read 511 times)
Fade in/out
June 19, 2026, 19:39:16 »
cmstein
Hi. I installed in my carOS AIMP 4.31.1732 version.
In Announces: "Sound fade-in/out settings are now can be defined separately for manual and automatic switching between tracks."
I couldn't find where to configure these timings. In the place where the track transition is configured, there's only one value to set.
Thank you.
Re: Fade in/out
June 19, 2026, 19:44:06 »
Карма: +1406/-190
Re: Fade in/out
June 19, 2026, 19:51:20 »
cmstein
I had understood that there would be a time for fade-out and another for fade-in.
In the Windows version, there are options to change the time of:
- fade out volume at the end of track;
- fade in volume at the beginning of track.
With the current options, it is possible to configure the mixing of cases (a) and (b) of the attachment.
With 3 times, other configurations will be possible, such as (c) and (d).
Fade in/out
