when I scanned the installer file with VirusTotal, it showed that, according to ESET Nod32, it's a PUP (potentially unwanted program). I've attached a screenshot of the scan.
Try uninstalling your antivirus and checking after a reboot. If that helps, your antivirus policy has become stricter.___If it doesn't help, then format the topic according to the rules.https://aimp.ru/forum/index.php?topic=5451.0
The problem lies in one or more of the following files:
Can you share these files?
I think it might be related to the YouTube or Hameleon plugin.
