DennoN
[x] [3067] Error with Programmer plugin in Aimp PC (w10)
Topic: [x] [3067] Error with Programmer plugin in Aimp PC (w10) (Read 850 times)
June 11, 2026, 03:07:58 »
tarufetti
Карма: +1/-0
Hello. I'm having trouble with the task scheduling plugin in AIMP PC.
The error occurs with the scheduler plugin. If I activate it, the application crashes. I need to deactivate it to be able to use AIMP without problems.
V6.00.3067 Beta 3
32-bit (03.06.2026)
Windows 10
executable : AIMP.exe
version : 6.0.0.3067
callstack crc : $3add9ec5, $eccd7d7e, $8965d539
exception class : EAccessViolation
exception message : Access violation at address 71E6FA4F in module 'AIMP.Runtime.dll' (offset 1CFA4F). Read of address 55555561.
Last Edit: June 11, 2026, 08:15:58 by Artem
Re: [3067] Error with Programmer plugin in Aimp PC (w10)
June 11, 2026, 08:15:54 »
Карма: +3216/-78
Thanks, fixed.
DennoN
