Move library to another location?
Topic: Move library to another location? (Read 1210 times)
May 03, 2026, 23:50:00 »
Nosfistis
Карма: +1/-0
My HDD which includes the library's audio files is dying, so I bought a new one and copied all files over. Is it possible to move all AIMP's library references to the new disk? (Windows)
I have tried swapping disk letters, but somehow AIMP uses the swapped letter instead of the old one.
Re: Move library to another location?
May 04, 2026, 08:14:40 »
Карма: +3224/-78
Disconnect the old drive, and invoke the "find misplaced files" function inside misc.menu of music library in AIMP.
May 05, 2026, 09:06:25 »
Nosfistis
Карма: +1/-0
Indeed by physically disconnecting the old drive it worked.
Previously, when having both disks online, the "find misplaced files" would seem to work, but after closing the window everything was reverted.
May 05, 2026, 11:14:05 »
Карма: +3224/-78
Did you delete the original copy of the data? Or, so, you have two copies for music files at different drives?
