[+] [3945] [Linux] Sound cracks and mini-hangups pulseaudio
Topic: [+] [3945] [Linux] Sound cracks and mini-hangups pulseaudio (Read 1021 times)
March 04, 2026, 01:49:16 »
ZipperZbieracz
AIMP: v6.00.3945 Alpha 9 [native deb version]
Linux version: Linux Mint 21.3 Cinnamon
kernel: 5.15.0-157-generic
The sound server on my OS is pulseaudio, and the default device detected by AIMP is "AO: Pulseaudio Output". When this device is selected, when music is played I can hear single "crack" sounds, sometimes the music also has a very short hangup, but it's mostly audible cracks happening at seemingly random intervals, but quite often. It happens on wired headphones and speakers, but it's obviously much easier to notice on headphones. It happens on FLAC and mp3, so I guess it's irrelevant what kind of file is played.
What's interesting, is the issue is non-existent when I switch fo: "ALSA: pulse", for every bit option
except
32 Bit , for which the issue is extremely severe. I think every other Bit option including "32 Bit (Float)" removes the issue completely.
What's even more interesting, the issue isn't 100% replicable, sometimes it goes away by itself or doesn't appear. Pulseaudio restart doesn't fix the issue when it's present.
Last Edit: March 04, 2026, 07:49:21 by Artem
Re: [Linux] [24bit] [v6.00.3945 Alpha 9] Sound cracks and mini-hangups pulseaudio
March 04, 2026, 07:49:06 »
Карма: +3216/-78
I cannot fix this on my side. libAO is not used anymore, default output is ALSA-based.
