Suggestions
the "Jump to time" function intervenes.
Topic: the "Jump to time" function intervenes. (Read 11280 times)
July 24, 2025, 22:01:52 »
Vaganza
When I'm trying to slide/ dragg the marker further on, on
the Android AIMP players control panel (the one that shows
how far the audio material has progressed) with my finger,
the "Jump to time" function intervenes (interferes with direct
seeking on the progress bar).
To try to just dragg fluidly enough with One's finger without
at the same time accidentally tapping on the control panel
seems, at least for me, impossible.
If I'd known the exact position of where I wanted the control
marker to land I would of course have marked that, but this
is just trying to approximately further the sound material along.
So my wish to the Developers would be for the average user
to inhibit the "Jump to time" function in the Android players
settings.
Should this issue already have been addressed in Russian,
as a nonrussian speaker, I wouldn't know.
Re: the "Jump to time" function intervenes.
July 25, 2025, 08:06:18 »
Карма: +3214/-78
Jump to time invoked due a long tap on seek bar. It will not invoked if you drag the position
July 25, 2025, 15:32:01 »
Vaganza
Thank you for your answer.
Quote from: Artem on July 25, 2025, 08:06:18
It will not (be) invoked if you drag (to) the position
If done quickly, yes, but if One seeks a position more
slowly, depending on the graphical structure of the
sound material, as seen on the control panel, the
"Jump to time" function will pop up.
Otherwise, One can of course just tap on a certain
position and hope that One has ended up in the
right (position).
There is an advantage of a displayed graphical
structure on the control panel as on the AIMP player
and that helps to set the cursor more precisely.
Last Edit: July 26, 2025, 02:16:29 by Vaganza
October 15, 2025, 00:24:39 »
Vaganza
There have been some updates since I last wrote,
but if there could be added either: 'Slide' or 'Continue
tap-and-drag’ to the box that now pops up would
be practical/ beneficial.
It's quite difficult to avoid touching the field without
tapping it instead of going to ”Slide” right away.
October 15, 2025, 08:18:01 »
Карма: +3214/-78
Ok
Suggestions
