[+] [2683][x64] Quck Search Playlist Issue
Topic: [+] [2683][x64] Quck Search Playlist Issue (Read 3834 times)
June 24, 2025, 13:38:49 »
g12345567
Running AIMP v5.40.2683 (11.06.2025) with "Pandemic v1.80" skin.
Playlist loaded is quite large playlist of internet radio stations. When doing a Quick Search from the search box at the bottom of the loaded playlist and then select one of results. Most of the time the radio station will start playing fine but also disappear from the playlist for some unknown reason. Then reappear back in the playlist when I press stop. However if I do an Advanced Search and select one of the results to play. The station and now playing data remain visible in the playlist.
Not sure if this is a problem with Aimp, The playlist or internet radio stream that is causing them to disappear/become hidden from the playlist when playing from the quick search results.
Last Edit: June 24, 2025, 14:05:16 by Artem
Re: [2683][x64] Quck Search Playlist Issue
June 24, 2025, 14:05:11 »
Карма: +3219/-78
I think it caused because metadata was changed due playback and the item stop matched the search query
