Seraching for a tab name only?
Topic: Seraching for a tab name only? (Read 4206 times)
May 05, 2025, 14:41:25 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
How could you search only the tabs / play list names? So only the tab with a certain name / part of it should be found.
Re: Seraching for a tab name only?
May 05, 2025, 14:49:43 »
Карма: +3229/-78
How many playlists you have in your collection?
May 05, 2025, 14:54:07 »
Карма: +476/-74
I am only familiar with searching by exact name through gradual typing of the name. See the image where the word sment is typed.
If you need to find among similar (same-name) or find part of a word, then such a search is not suitable. It is necessary to implement a quick search for playlist names under the list of names.
May 05, 2025, 21:57:14 »
Biff
Карма: +4/-0
How many, well, on the main drives there are shown about 30.000 .aimp files. Plus the new(er) plalist types.
Thank you for the image, yes, if I knew the beginning of a play list name I sometimes use it.
May 06, 2025, 08:01:57 »
Карма: +3229/-78
Quote from: Biff on May 05, 2025, 21:57:14
Unbelievable!
