Replaygain tag writing
Topic: Replaygain tag writing (Read 8248 times)
April 13, 2025, 16:22:22 »
haziness7913
Hello, I have a question regarding replaygain tags. I currently have the setting to use replaygain for volume normalization turned on, and my music files have replaygain tags previously written to them by a different program. So if I add new music those new files will be very loud. I was searching for a solution to this when I came across this post (
https://www.aimp.ru/forum/index.php?topic=69816.msg429129#msg429129
) that says the tag editor can write replaygain tags automatically to all files at once. I have been searching in the app, but where is this option, how can I do this?
Thanks.
Re: Replaygain tag writing
April 13, 2025, 17:18:36 »
Карма: +3209/-78
April 13, 2025, 19:59:25 »
haziness7913
Quote from: Artem on April 13, 2025, 17:18:36
Oh sorry, I'm using the Android app. Is this option there? I appreciate the help.
April 13, 2025, 21:19:48 »
Карма: +3209/-78
AIMP for Android has no this feature, it can use already written replay gain values from the tag
