How to remove the grouping headers?
Topic: How to remove the grouping headers? (Read 3028 times)
February 28, 2025, 18:53:59 »
A_62
Карма: +0/-1
Hello! I dont' want to have anything else than just the songs in my playlist. So i want to have all folder names gone. I've searched for hours, but couldn't find any setting to clean up the playlist. Where is that setting?
Re: How to remove the grouping headers?
February 28, 2025, 19:08:38 »
n.don n.pair n.cole
Карма: +2/-6
read music
February 28, 2025, 19:38:40 »
n.don n.pair n.cole
Карма: +2/-6
read music
You can also:
turn off smooth next tracking
turn off anticlipping
turn off song notification
February 28, 2025, 20:00:48 »
A_62
Карма: +0/-1
Thank you!
February 28, 2025, 21:03:35 »
A_62
Карма: +0/-1
Sorry, that was too early, the problem is still there, see the image below. It's just distracting in having those folder infos, how can i get rid of that? As you see, every second line is useless information and is annoying, when you just want to choose your Songs.
Last Edit: February 28, 2025, 21:28:20 by A_62
March 01, 2025, 01:51:29 »
Карма: +1406/-191
March 01, 2025, 03:43:15 »
A_62
Карма: +0/-1
Well, i have that option off. But it doesn't work. Maybe my config is faulty? Version is 5.40.2655 portable install.
March 01, 2025, 03:52:51 »
A_62
Карма: +0/-1
Ok, got it now! There was an extra option that has also to be turned off. Thanks!
