How to make a cue?
Topic: How to make a cue? (Read 7453 times)
How to make a cue?
May 21, 2022, 08:10:37 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
I have some flac files without a cue. How could I automatically make a cue file?
Re: How to make a cue?
May 21, 2022, 11:34:03 »
Карма: +1406/-190
Use tag editor
May 24, 2022, 10:14:18 »
Biff
Карма: +4/-0
How?
May 24, 2022, 10:27:57 »
Карма: +1406/-190
Quote from: Biff on May 24, 2022, 10:14:18
How?
May 24, 2022, 20:42:15 »
Biff
Карма: +4/-0
Ah, thank you.
So then one has to listen to that music of the music file with that player there and / or jump to the areas of the line without sound and there add a new entry for the new track and so on.
And after save these. What is better:
CUE, embedded to audio file
CUE, placed as separate file
February 04, 2025, 18:16:26 »
PegHorse
Hi,
How to modify an existing CUE ?
I can't see any "Load" or "Import" features.
February 04, 2025, 19:03:12 »
Карма: +471/-73
When you edit the file and save chapters, you are prompted to save to an external CUE (one of the options). You can drag this CUE into the editor and start editing chapters again.
How to make a cue?
