I created a playlist on the mob app. How to disable autoplay of all tracks.
Topic: I created a playlist on the mob app. How to disable autoplay of all tracks. (Read 5152 times)
January 17, 2025, 18:28:13 »
Plainman007
Hi i just installed AIMP for android. I created a playlist with 15 songs. I want to view the playlist and click on one song and after that it should stop. Not go automatically to the next song. I want to me able to manually choose which song to play and at finish of song, it should stop. I cant seem to find how to do it. Or can i do it without using playlists. Is there a mode where i can just view the list and tap a song to have ONLY that song play ONCE. Then next song i will tap again manually and it will play only that song ONCE. Plz tell me how to do this. In otherwords... dont want auto play.
Re: I created a playlist on the mob app. How to disable autoplay of all tracks.
January 17, 2025, 18:31:38 »
Карма: +1399/-189
Preferences - playback
January 17, 2025, 18:41:37 »
Plainman007
Ok i got it. But on this playlist panel...i cant control volume in anyway is it ?....other than using the mobile hardware buttons ?
I can seem to use volume slider only on the main panel where it hides my playlist away.
Additionally i just noticed that its trimmed a few select files. As in 4 min long songs are showing as 1.2 mins and 1.4 mins etc and they are playing also till that shortened time and stopping. The actual files are all 4-5 mins long. Its doing this to some files only.
Last Edit: January 17, 2025, 19:21:04 by Plainman007
