Is there a shortcut or can one create one to jump back in a running track?
Topic: Is there a shortcut or can one create one to jump back in a running track? (Read 2823 times)
November 22, 2024, 23:34:49 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
Is there a shortcut (e.g. CTRL+TAB or SHIFT+TAB) or can one create one to jump back in a running track (like you can jump forward with TAB)?
Last Edit: November 24, 2024, 15:54:44 by Artem
Re: Is there a shortcut or can one create one to jump back in a running track?
November 23, 2024, 19:05:07 »
Карма: +3215/-78
Quote from: Biff on November 22, 2024, 23:34:49
Tab is used to navigating between input controls, by default. Refer to rewind / fast forward commands in hotkeys settings of app
November 24, 2024, 12:31:22 »
Biff
Карма: +4/-0
Where can I find it:
Ah, found it, it's "Seek...".
Many thanks!
