Settings Button/Option Needed.
Topic: Settings Button/Option Needed. (Read 2316 times)
August 05, 2024, 02:43:19 »
Divine_Rapier
Hi, Could you please add a profiles or possibility to change specific settings done for a song to that song?
Like the Equalizer has Prefered Presettings for specific song.
ok how did i get here?
Been playing with the Settings on a Song for the past 3 days and while it's still a work in progress i kinda wanna listen to another song now, till i get to record this one.
Or a way of starting up a new Instance of the Program that would work as well.
Thanking you in advance, feel Free to Message.
Re: Settings Button/Option Needed.
August 05, 2024, 08:08:33 »
Карма: +3227/-78
What settings must be stored to a preset?
August 05, 2024, 15:23:21 »
Divine_Rapier
The one used most often would be the "Speed"bar but also "BASS", "Stereo Enchancer", "Reverb" and "Chorus" those would be the ones i use most often.
August 05, 2024, 21:29:45 »
Карма: +3227/-78
Thanks
