can peak normalization at 0dB cause clipping
Topic: can peak normalization at 0dB cause clipping (Read 2199 times)
April 22, 2024, 09:09:36 »
drugo
Карма: +3/-0
Aimp Rocks
Hi
i have enabled peak normalization at 0dB , a can hear clipping even with audacity there are no clipping /clipped part
I have set to -0.02dB , even 0 is the default
might you please check it ?
thanks
Re: can peak normalization at 0dB cause clipping
April 22, 2024, 13:55:10 »
Карма: +3230/-79
I need more information about the issue
