How to play a DJ mix without breaks between tracks
Topic: How to play a DJ mix without breaks between tracks (Read 5348 times)
February 10, 2024, 22:29:46 »
Mate M.
Hello AIMP pros,
I have some DJ sets and mixes that are divided in single parts/tracks, to be able to skip a track or jump to the next track in the mix.
All tracks of a mix are in one folder.
There're no silences at the beginning or end of a track.
But the AIMP playback is shortly interrupted everytime before the next track is played. Seems like AIMP is "calculating" something. This of course sounds stupid in a mix.
When I play the entire folder in JetAudio, the tracks are played sequentially as a mix with no pause.
I've already checked all settings where pauses between tracks are involved.
In the chapter "Mixing" only the checkbox "automatically jump to the next track" is activated.
Do you have any tips on how I can achieve smooth playback?
Addendum:
AIMP can play without breaks. Just tested it. But in some circumstances it plays with breaks, e.g. when I start playing the tracks from the folder.
Re: How to play a DJ mix without breaks between tracks
February 11, 2024, 04:36:16 »
CkopoxoD
Карма: +151/-1
Hi, try to enable the "Pre-load next track while current is playing" option (Preferences > Sound output).
