AIMP ASIO/WASAPI settings question with Dac Amplifier
Topic: AIMP ASIO/WASAPI settings question with Dac Amplifier (Read 6539 times)
November 17, 2023, 15:41:46 »
Juuza
Hi everyone. I'd like to ask for some advice. I'm using my integrated amp to play music from my pc, my amp's DAC drivers are ASIO and play files via usb 2. 0 up to 32 bit/384kHz, the Windows audio settings are on 24 bit/384kHz if I set the ASIO drivers to AIMP in the same way they don't bypass the other sounds, and I have to set the kHz offset either higher or lower to make them work, whereas if I set AIMP with WASAPI Exlusive 24 bit/384kHz everything works correctly, how can I solve this? Even if the DAC drivers are ASIO can I use WASAPI Exlusive without any loss of quality? Thanks for your advice
Re: AIMP ASIO/WASAPI settings question with Dac Amplifier
November 17, 2023, 15:48:37 »
Карма: +1406/-190
Your sound card's ASIO - fake
use WASAPI
November 17, 2023, 15:48:52 »
Карма: +3215/-78
Quote from: Juuza on November 17, 2023, 15:41:46
Yes, it works like ASIO
November 17, 2023, 15:55:53 »
Juuza
The drivers are these CA USB Audio 2 Driver v5.27.0 the amplifier is Cambridge Audio CXA81
