[x] [2432] when "Always show content of subfolders" is unchecked...
Topic: [x] [2432] when "Always show content of subfolders" is unchecked... (Read 7293 times)
June 14, 2023, 18:49:08 »
andybk-ma
Hi, using Windows 10 Aimp 5.11, when Preferences > Music Library > "Always show content of subfolders" is UNchecked then upon exit and restart Aimp does not remember your last position inside your Music Library. If you do check "Always show content of subfolders" then Aimp does remember upon exit and restart. Can you please fix? Cheers :-)
Last Edit: June 19, 2023, 09:43:20 by Artem
Re: [x] [2432] when "Always show content of subfolders" is unchecked...
June 19, 2023, 09:47:21 »
Карма: +3221/-78
Thanks, Fixed.
