How does one use the file Catalogs-Radio.ini in the System subfolder?
Topic: How does one use the file Catalogs-Radio.ini in the System subfolder? (Read 3181 times)
July 18, 2025, 19:32:33 »
sveakul
Карма: +81/-1
I see it contains code for the Shoutcast and Icecast directories, but how is it loaded into AIMP to make use of it?
AIMP 5.40.2683 Portable 64-bit
Re: How does one use the file Catalogs-Radio.ini in the System subfolder?
July 18, 2025, 20:53:37 »
Карма: +1406/-190
http://www.youtube.com/watch?v=oaVPwH1s-jE
July 19, 2025, 21:52:33 »
sveakul
Карма: +81/-1
Thank you Soolo; I forgot it's as simple as following the link from the "+" button on the bottom of the playlist.
