Playback options
Topic: Playback options (Read 2494 times)
Playback options
December 05, 2022, 00:25:29 »
musimath
Hello. I am using an AUNE USB Mini DAC-Amplifier connected to a 64-bit Windows 10 Sony VAIO laptop. I am trying to optimize sound quality.
When I choose in AIMP Playback options WASAPI: Windows default, or WASAPI: Speakers (USB Audio DAC), I get the following parameters: 48000 Hz, 32 Bit, but if I choose WASAPI Exclusive (Event): Speakers (USB Audio DAC) the second parameter changes to 16 Bit. In any case, when I play HiRes audio files (e.g. 192 kHz, 32 Bit) I get the following data from AIMP Options:
Input: 192000 Hz / 32 Bit (Float)
Output: 48000 Hz / 32 Bit
Is it possible to get 192000 Hz output?
Thank you.
Re: Playback options
December 05, 2022, 08:43:29 »
Карма: +3216/-78
Output is depended from capabilities of your hardware. In exclusive mode, AIMP uses DAC directly and blocks an access to other applications. In shared mode (default), AIMP uses OS-default output settings (it can be changed in Windows OS's control panel)
Playback options
