Editing a Playlist on Android
Topic: Editing a Playlist on Android (Read 3385 times)
October 14, 2022, 06:18:44 »
GeorgeTehachapi
I'm new to AIMP. On Android, when I add files to a playlist, it doesn't show me files that are already in the playlist when I'm in the "Add Files" dialog. Is there any way to have it show check marks next to files that were added in a previous Add Files operation?
Re: Editing a Playlist on Android
October 14, 2022, 08:16:06 »
Карма: +3229/-78
AIMP will ignore already added files. So, you may select entire folder and player will added only new files. Additionally, you can use the swipe-to-refresh gesture for same action
