Manually rearranging tracks order?
Topic: Manually rearranging tracks order? (Read 9131 times)
January 09, 2023, 16:27:38 »
rado84
Карма: +3/-4
Bulgarian
In older versions of AIMP for android there was a possibility to tap and hold a finger on a track and then move it up and down to change in which position you want it to be played. But in the current version that's not possible. Is there any other way to rearrange the order of tracks in a playlist? Or should I get back to my old practice of enumerating file names?
Re: Manually rearranging tracks order?
January 09, 2023, 17:31:15 »
Карма: +1408/-191
Use sort button
