AIMP for Android v4.30
[x] [2366] AIMP doesn't remember the sorting in "Managing Playlists" module
Topic: [x] [2366] AIMP doesn't remember the sorting in "Managing Playlists" module (Read 13609 times)
March 07, 2022, 03:57:11 »
schalmock
Карма: +2/-0
I would like to mention a minor annoyance that occurs in the "Managing Playlists" module for me.
It has existed for several builds, but I can't tell when it first appeared.
The problem: AIMP does not remember the sorting of the first 2 positions in the playlist overview of the module.
I have numbered my playlists, so sorting by the digits at the beginning should be fine.
When I call the module "Managing Playlists", playlist "02. ...." always appears on position 1 (Playlist_1.jpg.),
although the list was sorted before I left the module last time. The sorting works correctly (Playlist_2.jpg), but the next time the module is called it is again in the wrong order as in picture 1.
It's not a really big error, I can live with it, but it's still annoying.
It also only happens on the first 2 positions of the list, all other positions stay sorted correctly.
This error only appears in the "Managing Playlists" module. The list of playlists in the main window of AIMP are not affected, they stay sorted correctly.
Is there any way to turn off this annoyance?
Last Edit: March 07, 2022, 21:43:56 by Artem
Re: [2366] AIMP doesn't remember the sorting in "Managing Playlists" module
March 07, 2022, 21:43:52 »
Карма: +3209/-78
It seems that playlists displays in reversed order. I will fix it
Re: [x] [2366] AIMP doesn't remember the sorting in "Managing Playlists" module
March 07, 2022, 21:52:34 »
Карма: +3209/-78
Here is nightly build with a fix:
https://disk.yandex.ru/d/fZm3ebaba2qEeA
March 08, 2022, 01:25:25 »
schalmock
Карма: +2/-0
Thanks for the quick response.
Unfortunately the build 2367 only made the error worse.
Previously, only the first two positions in the list were in reverse order when opening the module.
From position 3 on, the order was correct.
After clicking on "Sort by title" the list was sorted correctly, but AIMP seems to forget that, because the next time the module was opened
the first two positions were swapped again.
With build 2367 after "sort by title" the playlist "01. ..." appears at the first position, but all following playlists are sorted in descending order.
(Playlist_3.jpg)
At next start of the module this sorting remains and does not change.
March 08, 2022, 10:08:47 »
Карма: +3209/-78
Thanks.
I have updated the fix:
March 08, 2022, 19:16:36 »
schalmock
Карма: +2/-0
Great!
The error is eliminated.
Thanks a lot!
