%FileName format string has no extension
Topic: %FileName format string has no extension (Read 2857 times)
January 26, 2022, 23:11:30 »
TomY
Hi,
I found that the
%FileName
format string in the playlist does not display the file extension, only the name part.
How can I display the full filename including the extension (= name.ext format)?
Thanks.
Re: %FileName format string has no extension
January 26, 2022, 23:24:37 »
d100s
Карма: +1/-0
%F.%E
%FileName.%FileFormat
