[x] [1178] не могу смахнуть влево на панели текстов песен
Pages:
All
Topic: [x] [1178] не могу смахнуть влево на панели текстов песен (Read 16554 times)
Re: [x] [1178] не могу смахнуть влево на панели текстов песен
Reply #15 on:
January 23, 2022, 10:48:37 »
AJ
Тестер-Ветеран
Карма: +298/-8
На 1180 стало хуже прежнего: у меня в большинстве случаев срабатывает перелистывание на плейлист, чем на инфо о треке.
Reply #16 on:
January 23, 2022, 11:19:32 »
Rfx9123
Завсегдатай
It would be better to improve a beta version first than refer to an unfinished alpha from here. I've tested the last three alphas, but the swipe gestures between the playback window and the window for showing all tracks in a playlist don't work in aimp_3.22.1180_Alpha_internal. In latest aimp_3.21.1178_internal the problem with the selection of the equalizer presets seems to be solved, instead, covers are no longer displayed when playing Internet radio.
Reply #17 on:
January 23, 2022, 11:43:32 »
Карма: +3230/-79
In latest alpha
, I have rollback all my changes that was made for swipe gestures. Now it should work as it was in 3.21.1178. Is not it?
Last Edit: January 23, 2022, 12:05:49 by Artem
Pages:
All
