Custom Multi-Channel Remapping for 7 Channels
Topic: Custom Multi-Channel Remapping for 7 Channels (Read 5133 times)
October 12, 2021, 19:44:50 »
2nd.Identity
Hi all, is there a way I can remap 7 channels to stereo (basically 6.1 channels to stereo)?
I am using the desktop version v4.70 build 2254.
I have tried "Allow channels mixing - Channels remapping" but could not find any working template for 7 channels.
I have tried all the templates from "mono to stereo", "stereo to stereo", "quad to stereo", "5.1 to stereo" and "7.1 to stereo", and it does not seem to affect the sound.
Appreciate any answers. Thanks!
Last Edit: November 08, 2021, 19:20:28 by 2nd.Identity
Re: Custom Multi-Channel Remapping for 7 Channels
October 12, 2021, 21:08:41 »
Карма: +3229/-78
Source file is 6.1? What is format used for?
October 13, 2021, 00:45:42 »
sveakul
Карма: +81/-1
6.1 is (now mostly "was") a technology transition between 5.1 and 7.1 that included only one rear channel instead of two discrete ones like 7.1. There are still DVDs encoded with it, and some receivers that can play it.
October 13, 2021, 03:56:11 »
2nd.Identity
Thank you Artem and sveakul for your replies.
The file I am playing is FLAC (encoded from WAV, if this helps).
I have attached a screenshot from MediaInfo showing the channels - L, R, C, LFE, C (back), L (side) and R (side).
I agree with sveakul that 6.1 may be a less common channel configuration, but would still be helpful to be able to custom remap the channels to the proper channels in stereo.
October 13, 2021, 07:08:09 »
ss.pl
Карма: +167/-9
Hi,
2nd.Identity
Is the player mixing the channels wrong somehow?
I can not understand what you are trying to get with the aimp mixer. Can I get a file to explore?
you can
upload here
October 13, 2021, 07:33:12 »
2nd.Identity
Hi ss.pl, thank you for looking into my query.
I have uploaded two files to the link you provided.
Both files are extracted from the same source.
a) 10. Be Yourself_full.flac:
This file has all 7 channels active.
b) 10. Be Yourself_isolate.flac
This file rotates through all the channels with only 1 channel active at a time and other channels muted.
Using this file I can hear that the mixing is correctly assigning Ch1 to left, Ch2 to right and Ch3 to left + right.
However, it is wrongly assigning Ch4 (LFE) to left and Ch5 (Center back) to right.
Ch6 and Ch7 seems to be correctly assigned to left and right respectively.
Furthermore, the custom remapping also offers volume adjustment for different channels which is a very powerful function.
The auto mixing seems to be soft to my liking, assuming it defaults to 25% - 50%.
I hope we can use custom remapping on 6.1 files too
October 13, 2021, 08:21:12 »
ss.pl
Карма: +167/-9
Quote from: 2nd.Identity on October 13, 2021, 07:33:12
Let's wait to see what the developer has to say.
2nd.Identity
thank you, I'll be testing.
Артём, расшарил
папку
October 13, 2021, 08:37:16 »
Карма: +3229/-78
Thanks, I will check it soon
Reply #8 on:
November 08, 2021, 19:20:04 »
2nd.Identity
Thank you all for adding mixing for 7 channels in the latest update v5.00 build 2342.
It is working flawlessly for my purpose.
Cheers!
