Suggestions
DennoN
Suggestions (playback follows cursor, RGB accent)
Topic: Suggestions (playback follows cursor, RGB accent) (Read 9668 times)
October 09, 2021, 14:59:37 »
martsum
Just switched over from foobar, sad it took me so long to find this!
Is there any feature like 'playback follows cursor' in AIMP? Simply selecting a track with the mouse with make it play next. I used that a lot in foobar. Also ability to set RGB values for the accent colour would be great!
Re: Suggestions (playback follows cursor, RGB accent)
October 09, 2021, 22:44:52 »
ss.pl
Карма: +162/-9
Hi, martsum!
Use the "Q" key to queue up the track.
Also, try using the right-click context menu.
In the playlist, you can deactivate tracks with the checkbox on the left side.
Aimp uses the HSL model
https://www.aimp.ru/forum/index.php?topic=67328.0
https://www.aimp.ru/forum/index.php?topic=58775.0
p.s. translation difficulties:
QTranslate
(+DeepL)
Suggestions
DennoN
