Stopping Aimp to keep checking for update
Topic: Stopping Aimp to keep checking for update (Read 4431 times)
July 07, 2021, 11:27:03 »
Marty
Hi y'all. I'm using 2.61 build 583 with Windows 7 Home Premium 64bit Sp1. very recently i've make some hardware changes into my pc and i've installed a fresh and clean Windows. since a very short period i've keep getting a message to update my aimp and i don't want to update it. How can i prevent aimp to keep check if it's any newer version, and aditionally if needed too, how can stop to show me the new update ,,reminder" ? Thank you for your time, and i can wait to see your answer/solution !
Re: Stopping Aimp to keep checking for update
July 07, 2021, 14:08:23 »
Карма: +3224/-78
Why you don't want to update the player?
July 08, 2021, 14:13:53 »
Marty
i like the menus and the interface.
July 08, 2021, 14:18:30 »
Карма: +1406/-191
https://www.aimp.ru/?do=catalog&rec_id=162
July 08, 2021, 14:26:28 »
Карма: +3224/-78
Quote from: Marty on July 08, 2021, 14:13:53
You can use old skin with new version.
