SKIPPING PROBLEM
Topic: SKIPPING PROBLEM (Read 4804 times)
SKIPPING PROBLEM
July 24, 2019, 21:31:10 »
apometron
How to stop the skipping?
I cant hear nothing.
I think I used any hotkey to activate the automatic skipping.
Please, help.
Last Edit: July 24, 2019, 21:41:02 by Artem
Re: SKIPPING PROBLEM
July 24, 2019, 21:41:23 »
Карма: +3213/-78
What is automatic skipping? When it happened? Can you explain in more details this effect?
July 24, 2019, 21:56:02 »
apometron
The music plays 1s or 2s and then it skips.
How to disable it?
It started today.
[]s
Rodrigo César Bagnara
http://about.me/bagnara
July 24, 2019, 22:05:08 »
Карма: +3213/-78
What is your version?
July 24, 2019, 22:16:11 »
apometron
v4.51 build 2084
July 24, 2019, 22:46:13 »
apometron
I will use the record function of ShareX for the first time and I will record the strange behavior.
I need help.
July 24, 2019, 23:01:21 »
apometron
I would record, when something funny happened.
I deleted the database data and then the behavior did get back to normal.
No more skipping.
Why this happens?
[]s
July 26, 2019, 08:52:37 »
Карма: +3213/-78
What exactly you have deleted? What plugins you have installed?
Reply #8 on:
December 28, 2020, 05:41:09 »
apometron
The problem changed. Now it is another thing, I will start another topic.
SKIPPING PROBLEM
