My equaliser settings are missing
Topic: My equaliser settings are missing (Read 1825 times)
August 30, 2020, 15:46:27 »
nicgentile
So,
Last month I spent two straight nights custom setting equalisers for each song on my playlist. Over 500 songs. Today, I was building a playlist and about 90% of the custom equalisers for the songs were gone. Is it a bug, or is there a limit to how many songs you can build custom equalisers for?
Thanks
Re: My equaliser settings are missing
August 30, 2020, 18:44:40 »
sveakul
Карма: +81/-1
Did you check inside EQPresetsLibrary.ini in your Profile folder to see if they're actually gone? Maybe there is a limit to how many the GUI can load at once for selecting, but Artem would have to comment on that.
