Skin Editor, Skin Engine
How can I change the background color to the art color of the song that is playi
Topic: How can I change the background color to the art color of the song that is playi (Read 11720 times)
May 28, 2020, 08:28:38 »
PacoElPajas
In the mobile version there is an option that allows you to change the color to "skin based". How can I do this in the PC version?
Last Edit: May 28, 2020, 23:10:30 by PacoElPajas
Re: How can I change the background color to the art color of the song that is playi
May 28, 2020, 10:47:23 »
Карма: +3210/-78
What you mean? Can you explain in more details?
May 28, 2020, 21:59:04 »
PacoElPajas
https://imgur.com/gallery/ikgNw27
You can see that the color changes depending on the art of the song that is playing. How can this be done in the PC version?
Sorry for my bad english I use translator
May 28, 2020, 22:45:43 »
Zhenya
Тестер 3-го уровня
Карма: +328/-8
Quote from: PacoElPajas on May 28, 2020, 21:59:04
This is a function of Android, not AIMP.
For AIMP for Windows try
Hameleon
plugin.
There is also a similar feature request for skin makers — «
Возможность получить цвет рассчитанный на основе обложки альбома
» (in English: "Ability to get a color calculated based on the album cover").
